woods loop
Re: woods loop
Post by Wingfixer »
thetable wrote:
Wingfixer wrote:Long range, splong range. Progress report:
How's your silencer/chain/swingarm clearance? Those side screws definitely look wide enough that I'd be replacing a silencer.
Its a fairly flat profile tire, the screws on the sides don't stick out any further than the knobs when its inflated.
Finished product:
I glued used tubes inside the tires to protect the tubes from the screw heads. All in cost was $32 and change, $21ish was for the screws. I could remove and replace all the screws in about 2 hours + the dismount remount time. Not too bad when you compare these to the cost of for-real ice spiked tires.
They have been delivered, look for a ride report coming to an icy trail near you!
Re: woods loop
Post by Wingfixer »
Kyler wrote::killingme: is this for Buttercup? :jack:
You guessed it! :whoop: :target:
Re: woods loop
I'm interested in how long they last. Also, did you pre-drill holes or did you just screw the screws in?
Skinny-J
Re: woods loop
Post by Skinny-J »
Look what Tulip just dropped off, He is too good to me
Bring on winter Bitches!!
:roost:
Re: woods loop
Post by gots_a_sol »
I'd have made him mount them up too. Looks painful.
GMER/WATR member
'17 Beta 250RR/RE
'17 Oset 20.0
Re: woods loop
A quick search of Grainger reveals case hardened sheet metal screws at reasonable prices...
Re: woods loop
Post by Marylander »
I rode with a guy in central Mass who did the screw thing. He put the screws in the other way around so the head was facing out rather than the point. He at least thought they worked best that way.
Re: woods loop
Post by Wingfixer »
juddspaintballs wrote:I'm interested in how long they last. Also, did you pre-drill holes or did you just screw the screws in?
I pre-drilled them with a #30 (1/8") drill, it got impressively hot.
Re: woods loop
Post by Wingfixer »
gots_a_sol wrote:I'd have made him mount them up too. Looks painful.
Your off the Christmas list. :dirtdog: I told Jay to have the Red Cross standing by when he mounts them. :killingme:
Marylander wrote:I rode with a guy in central Mass who did the screw thing. He put the screws in the other way around so the head was facing out rather than the point. He at least thought they worked best that way.
I mounted them this way to 1) reduce the chance of putting 296 tiny holes in your tubes and c) not distribute 296 tube killers on the trails. The screw you loose will be the one you pickup, in your tire.
bonehead
Re: woods loop
Post by bonehead »
I have buckets of screws for all who want to be screwed. Just let me know.
