KTM? The aluminum nut is the likely culprit, get two, and an extra axle block. Carry the extra nut and block with you on the trail. If you don't thank me, then someone else will. (As in, it will be used sooner or later.) Unless you're OFG, that's a ride ender right there. Shouldn't be too hard to find one at a local shop, if you have time.juddspaintballs wrote:Wife texted me a picture of my chain adjuster she found in the driveway today. I'm at work right now and have the bike with me. I hope to be able to assemble the rear axle and chain adjuster when I get home (hopefully) tomorrow. If I can't (possible stripped threads?), I won't be able to ride. I'll know more tomorrow and will keep you informed.
Oh, and the factory torque spec (59lbft) is way too high. 35lbft is what I usually go with.
