Noice, definitely jealous of that!
Trying to sort out the carb on my garage queen Beta. She was pissing gas for a minute.
The alternator seized on my Kubota L2250 tractor. I've been expecting that since the charging system is kaput. No big deal since it is a diesel; just charge the battery frequently. I had a regulator waiting and a chinese alternator was only $70. Got a new belt from NAPA for $10 or so.
The alternator is easy to get to. Had it off in 15 minutes. There is a fan shaft that runs from the water pump forward to the fan. It is supposed to collapse like a PTO shaft. Two hours later, and two cans of PB Blaster, the rain started. &^%$# shaft is rusted tight and it isn't obvious how to get it off without disassembling the front of the tractor. ARGHHHH!
post a pic so that we all can laughRut Row wrote: ↑Tue Mar 03, 2020 7:14 amThe alternator seized on my Kubota L2250 tractor. I've been expecting that since the charging system is kaput. No big deal since it is a diesel; just charge the battery frequently. I had a regulator waiting and a chinese alternator was only $70. Got a new belt from NAPA for $10 or so.
You should have left room in your garage to do actual garage work
Try heat to loosen it up.
I hope someday to have space in the shop for this kind of work
It's the shaft that sticks out of the pump pulley. I think I can get the spacer (those nuts in the middle are where the spacer should be) out and slide the belt through there. If not, will be getting out the torch!
It is ORANGE, what do you expect?
I didn't actually do any real work yet but I found the source of the coolant that's been dripping from my versys. A rock or something punctured the radiator. I managed to find an oem one on ebay that looks good. It was a little more than a new one from China but I decided to go the safer route.
Myler's Radiator does awesome work!Marylander wrote: ↑Tue Mar 03, 2020 3:17 pmI didn't actually do any real work yet but I found the source of the coolant that's been dripping from my versys. A rock or something punctured the radiator. I managed to find an oem one on ebay that looks good. It was a little more than a new one from China but I decided to go the safer route.
https://www.motorcycleradiators.com/pro ... tor-repair
Users browsing this forum: No registered users and 41 guests
