Re: The KAT -Part Deux discussion thread
Re: The KAT -Part Deux AND Hatfield McCoy Buffalo Mountain 7/18 to 7/26/2020
My motomined center cluster thing comes with a builtin on/off button. Wired into the headlight, I think. That would work.
aai
Post by aai »
which MotoMinded kit did you get Bruce? I installed the small version and very happy with it. The on/off Button you speak of is a ground wire interrupt for the dual USB/Volt readout port. So it should work for anything if you run your ground wires thru it. Or get another one, enough room on the plate for it.
aai wrote: Tue Feb 04, 2020 11:22 am which MotoMinded kit did you get Bruce? I installed the small version and very happy with it. The on/off Button you speak of is a ground wire interrupt for the dual USB/Volt readout port. So it should work for anything if you run your ground wires thru it. Or get another one, enough room on the plate for it.
That's the one I have. I just don't remember how that little button is wired.
BDMaha
Post by BDMaha »
I'm having a week long family reunion the week b4 this ride. Work will allow me to do the single track at Buffalo mountain which is close to my parents reunion. My question is what range is to be expected. I'm on husky 300.
2018 KTM 500 Exc-f
2017 Husky TX300
2016 Honda 500x RR
BDMaha
Post by BDMaha »
Do I need a bladder of premixed or just some oil for fuel stop. I e only done the southern 4 Hatfield trails
2018 KTM 500 Exc-f
2017 Husky TX300
2016 Honda 500x RR
BDMaha wrote: Mon Feb 10, 2020 2:07 pm I'm having a week long family reunion the week b4 this ride. Work will allow me to do the single track at Buffalo mountain which is close to my parents reunion. My question is what range is to be expected. I'm on husky 300.
Your stock tank should be fine.
Yes, have some oil in your gear for refueling.
I always carried mine in a baby bottle. The side is already marked with ounces.
Other guys prefer to carry several of the little 1 oz bottles of oil.
Post by Wingfixer »
Phil, it's your Beta not oil injected anymore?
BDMaha
Post by BDMaha »
I'm a solid 90% in for the buffalo mountain ride!
2018 KTM 500 Exc-f
2017 Husky TX300
2016 Honda 500x RR
BDMaha wrote:I'm a solid 90% in for the buffalo mountain ride!
Respond to the KAT planning thread also. Image
Wingfixer wrote: Tue Feb 11, 2020 9:02 am Phil, it's your Beta not oil injected anymore?
Still oil injected. I was referring to how I used (past tense) to carry oil on my old KTM 300
