Page 16 of 67
Posted: Mon Apr 20, 2020 2:02 pm
by gots_a_sol
Another project followed me home. Supposedly has a trans issue but seems to drive around the neighborhood fine.
Posted: Mon Apr 20, 2020 5:19 pm
I worked on my marksman proficiency.
Posted: Mon Apr 20, 2020 8:37 pm
Laoch wrote: ↑Mon Apr 20, 2020 5:19 pm
Nice!
Posted: Tue Apr 21, 2020 12:24 pm
New foot pegs installed and suspension shipped to Motolab. Time for a nap.
Posted: Tue Apr 21, 2020 9:22 pm
by gots_a_sol
The girlfriend has been using the hell out of the old frontier lately and it has spent quite a bit of time near the rear bumpstops these last few trips. I bought this air bag kit for my Xterra 5+ years ago but never bothered to install it on that truck. Might as well use it now.
Would have been super easy to install if all 4 of the factory bump stop bolts didn't snap off
I used the air hammer to break off the welded nuts then dropped in a bolt.
Wrapped a piece of solder in the threads, fed it through the frame and out the holes where needed. Easy peasy.
Next task is an easy to use air source to keep on the truck to air it up.
Posted: Mon Apr 27, 2020 5:52 pm
by Damage Inc.
Honey do, done. Well not hardly but at least these are hung.
Posted: Mon Apr 27, 2020 9:27 pm
by Bork
You mean there is no electric to it?
Posted: Tue Apr 28, 2020 11:05 am
by gots_a_sol
Replaced door hinges on the new Frontier. Probably could have replaced the pins and bushings but wasn't sure if the hinge pieces themselves were worn as well. The door was sagging enough the top corner had rubbed the paint off the B pillar.
Also replaced the spark plugs and a torn air boot at the throttle body.
Posted: Tue Apr 28, 2020 11:22 am
by Damage Inc.
Bork wrote: You mean there is no electric to it?
No fully functional with dimmer. That was the easy part. The issue was figuring out the Chinese directions, which was a picture of a similar chandelier. Ended up looking at the reviews at other people’s photos. And the fact that my ladder was a 14’ and I needed a minimum of 16’. I had to fashion some 2’ ladder stilts.
Posted: Tue Apr 28, 2020 5:25 pm
by J&J
Lets see some pictures of the ladder stilts.....
And did your wife see you on the ladder with them?
