Inner tube review thread
Getting new tires for the 06 klx250s and want to get new heavy duty tubes. Any input or opinions on what tubes you guys have used and liked.
06 klx250s(300)
04 fz6 sport tour
04 fz6 sport tour
Re: Inner tube review thread
I've used the IRC Ultra-Heavy Duty tubes, and I will say that if you pinch it under your bead lock, and inflate it, it will rip. Like a 4" long rip that can't be patched. In a never-used tube. The upside is that they make AWESOME rubber bands.
All kidding aside, I think normal Heavy Duty is fine - the UHD tubes will almost stand up in a corner on their own. I've used IRC and Bridgestone, both perfom adequately.
I've been using the Michelin Airstop UHD tubes. No complaints so far except they ain't cheap!
Kenda, Michelin and IRC. I run them in the KLR and the DR. No worries.
Bridestone makes a very thick tube. Ask for the heavy duty one.. forget what it was called. Costs around $20-25. Well worth the money. I think it's the thickest available.
i agree on the regular heavy duty opposed to the ultra heavy duty they have too much rubber in them.
I forget which but the Moose Tube and/or the MSR heavy duty tube is a michelin or other brand name in their packaging, usually for cheaper.
I run ultra heavy duty tubes because I like pressures below 13psi and I'm usually busy fixing someone elses flat I dont need my own
2002 XR650R (plated)
1990 TransAlp
2000 XR650R (trophy)
2002 CR125R
2009 Big Red
1977 CT90
2008 CRF230L (wifeys)
2003 XR650R (crackbabys)
1999 CR80R (crackbabys)
1972 XL250 (crackbabys)
1990 TransAlp
2002 CR125R
2009 Big Red
1977 CT90
I'm running Bridgestone UHDs in the 950 and 510. Zero flats in 35K miles between 'em.
I'm looking forward to installing TuBliss on the Husqy or better yet slash some real weight by getting a 2-smoker from Harold out at Ridersville. Rumour has it Husqy is releasing a direct injection 2 smoker in 2011 or 12 depending on the publication you're reading. Hmm ...
wow - I've been waiting for this to come out - they have been making it for small displacement motors for a while.Louge wrote:Rumour has it Husqy is releasing a direct injection 2 smoker in 2011 or 12 depending on the publication you're reading. Hmm ...
One of the problems Bimota had with the V-Due was high RPM pintle float. They couldn't get the larger pintles to open and close fast enough to support the 500cc motor. Not sure how the problem has been addressed but look forward to the end result.Kyler wrote:wow - I've been waiting for this to come out - they have been making it for small displacement motors for a while.Louge wrote:Rumour has it Husqy is releasing a direct injection 2 smoker in 2011 or 12 depending on the publication you're reading. Hmm ...
