quick compression check?
any sensors?
sounds electrical
check all connectors
good spark ?
try all 1 million things, 1 at a time
need DRZ motor help
Re: need DRZ motor help
Yeah, that is the way it goes.b3h wrote:quick compression check?
any sensors?
sounds electrical
good spark ?
Subsequently, I have been spending a lot of time on Ebay and craigslist.
Halle's TT-R125L exhibited a similar problem after sitting over a winter (and yes, with a full float bowl ). It ran fine up on the needle and main but wouldn't start or idle. I went through the carb a couple times before finding a jellified mass under the pilot, the pilot was fine. A dental pick plucked it out.
I don't believe yours sits long enuf to have those kinda probs mdubya. Any cracks on the intake boot?
Louge wrote:Halle's TT-R125L exhibited a similar problem after sitting over a winter (and yes, with a full float bowl ). It ran fine up on the needle and main but wouldn't start or idle. I went through the carb a couple times before finding a jellified mass under the pilot, the pilot was fine. A dental pick plucked it out.
HAHA, plus with as much as he gets it it up on one wheel, nothing should be settling!
How's the plug wire ?
bunch of bike I don't ride...
I saw that one.mtd679 wrote:http://baltimore.craigslist.org/mcy/1762494434.html
I need to take a good look at it. I was headed to the garage this evening when I was distracted by my guitar.b3h wrote:How's the plug wire ?
That is my theory.biffer99 wrote:HAHA, plus with as much as he gets it it up on one wheel, nothing should be settling!Louge wrote:Halle's TT-R125L exhibited a similar problem after sitting over a winter (and yes, with a full float bowl ). It ran fine up on the needle and main but wouldn't start or idle. I went through the carb a couple times before finding a jellified mass under the pilot, the pilot was fine. A dental pick plucked it out.
I need to check the intake boot. I think there is a strong possibility it is dirt or gunk in the carb.Louge wrote:Halle's TT-R125L exhibited a similar problem after sitting over a winter (and yes, with a full float bowl ). It ran fine up on the needle and main but wouldn't start or idle. I went through the carb a couple times before finding a jellified mass under the pilot, the pilot was fine. A dental pick plucked it out.
There is also a strong possibility I will have a spare motor and a second DRZ before the weekend is up.
