Stinson wrote:
Sounds like good advice!! The hills you cant get back up, is that because they are switch backs or because they are just too steep? I love me a hill climb!!!
BOTH. The one hill in particular we are talking about is part of "Doctor's" trail and is a STEEP nasty, under trees (stays wet) section that snakes back and forth and to ride up it, would be a challenge, but if not to greasy, you could make it. Going down can be very entertaining as well. It is pretty steep in the final section of it. Most of the other "bad" hills have cinder block lining them, so they are good traction wise but still tough, especially if you loose the line, you gonna go downhill quite a ways. I definitely want to ride this again, it is an awesome trail and if it is dry and has been for a while, we SHOULD try to climb it. we can always turn around and go to the stream crossing.........
