Carb cleaning - lemon juice style
Posted: Wed Apr 17, 2013 1:35 pm
Had to clean the carb recently and tried out the “lemon juice” method, thought I’d pass it on. I’m sure many of you guys have tried and true methods, I guess the theory on this one is that lemon juice is very acidic and can clean as well or better than carb cleaner and other chemical solutions. You can read about it many places on the net, so it must be true
My experiment was just with the bowl for starters. Here’s a few before pictures:
Not a nightmare, but a good deal of varnish and gritty stuff. Hit it with carb cleaner and did some lite scrubbing, still had this. On the right I really scraped at it.
So I broke it down as far as it would go, left the gasket where it was, put all the pieces into a tin can, and filled with this stuff, which is quite inexpensive:
Put it on the stove and brought to a very low boil. This was a bit of a mistake as it ends up STINKING pretty bad! When I went back and did the jets, I used a camp stove outside. I’ve read you can let it just soak for a couple days, but I wanted the quick results.
Let it heat for 20 minutes, cool down, wash thoroughly with warm water, dry, air out the house, and voila!
The pictures show it pretty well, I think it did a really good job, just a little mess there in the upper middle, but it came off easier with a little scrub.
Heres a shot while getting it back on, makes the top look like junk.
