DRZ 400 rpm/gearing/speed
Ok, it's a KLX400 but a DRZ.
I'm running 15/47 and it seems to top out at 55-60 mph. Just kind of starts to hesitate.
Runs awesome strong up to that point and does well off road.
I'm wondering is that normal based on the bike and gears.
I put a TTO tiny tach on it and at 55-60 mph I'm running about 3k rpm. Seem right?
I know those tachs are nor very accurate.
It's piped and probably jetted by PO, will that make a difference?
I ride mostly back roads, where it does well, but for the occasional stretch where I want to run faster, it ain't happening. If it's normal, then I'll live with it.
- RadioRyder
Re: DRZ 400 rpm/gearing/speed
Here is a link to some good info on DRZ gearing. I tried 14/47 for trail riding, but it was painful on the street. I went back to stock 15/44 for best compromise dirt / street.
http://www.paochow.com/DRZguide/DRZgea.php
_________________
Bryan
08 Yamaha YZ250F
08 Yamaha Raptor 250 SE
06 Suzuki DR-Z400S
Bryan
08 Yamaha YZ250F
06 Suzuki DR-Z400S
Mmmm. Good info. I might have a 44 laying around. If not I'll order one up and swap 'em out.
- DAMN n00b
DRZ400E stock gearing is 14/47. DRZ400S stock is 15/44. Internal gear ratios are the same for both models.
With 15/44 sprockets on my 2000 400E, topped out at 85mph (GPS indicated) after a 1 mile run, RPM not measured.
Based on the math, at the same RPM, the 14/47 gearing would have yielded 74mph (Factor = .874)
Your bike has a problem. My DRZ has 15/47 and does 90mph.
How old is the bike and how many miles? When was the last time you cleaned your carb, cleaned your petcock filter, cleaned your airfilter, and checked your valves?
What Billygoat said..... or most likely jetting if it's been like that since you've had it or put the pipe on it.
Ummmm...gonna do that next.BillyGoat wrote:How old is the bike and how many miles? When was the last time you cleaned your carb, cleaned your petcock filter, cleaned your airfilter, and checked your valves?
You guys are obviously right. It's either a jetting or a valve issue.
dirtygrunt wrote:Ummmm...gonna do that next.BillyGoat wrote:How old is the bike and how many miles? When was the last time you cleaned your carb, cleaned your petcock filter, cleaned your airfilter, and checked your valves?
Bruce you need to turn the throttle to make it go faster
Boom Boom wrote: Bruce you need to turn the throttle to make it go faster
Users browsing this forum: No registered users and 22 guests
