Before I put this on fleabay, I though I'd try here.
Generac 100A 14-Circuit Automatic Transfer Switch - NEMA 1
NEW transfer switch with 14 circuit Siemens load center
I have a Generac two pole, 100-amp automatic transfer switch with integrated load center. I bought a Generac 14 kW Air-Cooled Standby Generator and this transfer switch came with the unit as standard equipment. Unfortunately, I needed a 200-amp transfer switch so this one is surplus. The replacement switch did not come with a trickle charger so we took the trickle charger out of the 100-amp switch. You can get trickle chargers from any Generac dealer. Includes the 30' whip.
See http://www.guardiangenerators.com/Produ ... n14kW.aspx for more info.
No. of Poles 2
Current Rating (amps) 100
Voltage Rating (VAC) 250
Utility Voltage Monitor (fixed)
- Pick-up 75%
- Drop out 65%
Return to Utility Approx. 15 seconds
Exercised 7 minutes weekly Standard
UL Listed Yes
Enclosure Type NEMA 1 (Indoor rated only)
Enclosure Material Steel
Dimensions (H" x W" x D") 26.5 x 12.5 x 7
Re: Generac 100A 14-Circuit Automatic Transfer Switch - NEMA 1
Scotty, enough with the long winded explanation, I just need more power DAMNIT!!
bunch of bike I don't ride...
mtd679 wrote:Scotty, enough with the long winded explanation, I just need more power DAMNIT!!
Kyler,
My Dad might be interested in this, he needs to check his generator for compatibility. I will post here in a few hours if he wants it. PM me the price and if you can bring it with you tomorrow.
Patrick
Patrick
PM sent
..and replied
Users browsing this forum: No registered users and 32 guests
