Page 2 of 2
Re: Earthmovers
Posted: Wed Dec 03, 2014 7:51 pm
by Firebolter
gots_a_sol wrote:Firebolter wrote:You're gonna like my new little screamer I am building now! I got the head, cylinder and new piston back yesterday, so ready to install.
Husky 165?
Yup, a 165 built on a new/left over 13. Got mine done by Walt (of Cafe Husky fame). Valves installed from my 125 cylinder and cut to match the 165 bore. Walt installs and sets up the cylinder and send it's back ready to install.
Can't wait to get it installed and broken in. Walt uses Wossner pistons and they are really well made. Nicest piston I have ever seen. I added a Lectron to the mix, set up for the 165 by Kevin at Lectron with a "Husky" specific needle the 165 Boyz at Motosportz developed with Lectron. These guys have 2 years on these builds now, so should be pretty bullet proof.
Re: Earthmovers
Posted: Thu Dec 04, 2014 6:10 pm
by Taylor
Firebolter wrote:gots_a_sol wrote:Firebolter wrote:You're gonna like my new little screamer I am building now! I got the head, cylinder and new piston back yesterday, so ready to install.
Husky 165?
I think a side by side test should be in order. Stock 125 vs 165? That 165 will be sweet!
Re: Earthmovers
Posted: Thu Dec 04, 2014 8:49 pm
by gots_a_sol
Firebolter wrote:Yup, a 165 built on a new/left over 13. Got mine done by Walt (of Cafe Husky fame). Valves installed from my 125 cylinder and cut to match the 165 bore. Walt installs and sets up the cylinder and send it's back ready to install.
Did you get the 200 pipe as well?
I've had mine setup as a 165 for ~1.5 years now and have a bit over 100 hours on it. Other than the power valve issue, it has been flawless. 165/36mm lectron/200 ktm pipe + rekluse/lhrb = super awesome.
Re: Earthmovers
Posted: Fri Dec 05, 2014 10:58 am
by Firebolter
No, didn't get the 200 pipe yet only because I scored a brand new 144 kit that came with a brand new Fatty and power core can so I am gonna run that at first.
Want to ride it first with that pipe and break it in then maybe switch up to the 200 pipe later on. Definitely want to add the Rekluse after I get a feel for it first without it.
