Page 7 of 8
Re: Wasp progress report
Posted: Tue Aug 04, 2009 7:25 am
You could use minimal batteries just to power the lights and pass inspection.
Worry about a more permanent solution later.
Posted: Tue Aug 04, 2009 7:58 am
by Rut Row
Bucho wrote:You could use minimal batteries just to power the lights and pass inspection.
Yup - I think you are right. I can get a sealed battery for ~$50.
The permanent solution is the SV650 powered Hornet!
The Dual-Sport Wasp project is back on!
Posted: Tue Aug 04, 2009 12:47 pm
by Rut Row
Update - The guys on the CR500 forum say the 87 and later ignition from a CR250 and CR500 will retrofit. So, once I have more money I'll pick up a complete ignition system and install it.
Posted: Tue Aug 04, 2009 9:09 pm
by B DIRT
would the electronic ignition that service honda has work on this bike? or are you trying to stay as cheap as possible? I answered my first question except for the unavailable part
http://servicehonda.com/parts/ignition.html
Posted: Tue Aug 04, 2009 9:20 pm
by Rut Row
B DIRT wrote:would the electronic ignition that service honda has work on this bike? or are you trying to stay as cheap as possible? I answered my first question except for the unavailable part
if it had been available, that would have been the preferred option. Over on the CR500 forums, I've found out the CR250 ignition will fit... if yours comes up missing...
Posted: Mon Aug 10, 2009 6:51 pm
by Rut Row
Okay - turn signals, lights, horn, etc work using a spare battery versus installing a lighting circuit.
Next is to hook up the speedometer, install the temperature sensor, connect the turn signal indicators, etc.
Am installing the MT-16s and heavy duty tubes Saturday AM.
Then back to the fabricator/welder to make a battery box and mount, and fabricate a new front caliper bracket that includes a mount for the speed sensor.
It is getting there!
Posted: Fri Aug 14, 2009 7:42 pm
by Rut Row
Ain't color coordinated but...
and here's the speedo
With a bit of luck, by the end of next week it will be ready for inspection then off to register it!
Posted: Fri Aug 14, 2009 8:28 pm
by B DIRT
H O L Y F * * K ! !
ken I have wet dreams about flying down state forest roads on that bad boy
Posted: Fri Aug 14, 2009 8:34 pm
by Rut Row
B DIRT wrote:H O L Y F * * K ! !
are ya coming to Jersey end of the month?
Posted: Sat Aug 15, 2009 11:25 am
Getting some of those old tires off was definently a two man chore.
Fresh tires and a lower front sprocket. She is coming along nicely.
