Michaux DS 2023 HELP!!!
Posted: Wed Aug 16, 2023 6:44 pm
This OLD DUMMY can't figure out how to get the GPX file for this event on to his Garmin Montana 680t.
I have downloaded the GPX file and the directions for transfer to Garmin Basecamp but can't make them work.
The files are also available in other formats if that would help (KML and KMZ) and I have these instructions for GPX to Basecamp but CAN'T DO IT!
Of course if anyone else already has a Basecamp or other Garmin compatible file available that woiuld be GREAT!
THANKS FOR ANY HELP OR GUIDANCE!
Importing GPX Files into Garmin BaseCamp™ and Transferring the Data to a Garmin Outdoor Handheld
GPX files can come from a variety of sources and contain data such as routes, tracks, waypoints, and geocaches.
These files can be imported into our Garmin BaseCamp™ program to review on a computer and then transferred to a compatible handheld Garmin.
Importing and Transferring GPX Files
First, you need to import the GPX file(s) into BaseCamp™ software with the steps below.
1. Open Garmin BaseCamp™ software.
2. Select the File drop-down menu from the top toolbar.
3. Select Import...
4. Browse to the GPX file location from the Import File window.
5. Select Open for Windows, or Import for Mac.
Once the GPX file has been loaded, you should then be able to transfer the data to your handheld.
________________________________________
Transferring GPX Files to a Garmin Outdoor Handheld
Now you can select the data and transfer it with the steps below.
3. Select Import...
