Re: DAMN ADV ride
Posted: Fri Nov 20, 2020 4:33 pm
Sounds cool. Easy dirtroad/fireroad type dualsporting is fun for most any size bike.
Dual-Sporters/Adventurers of Maryland and Nearby
https://www.damnriders.org/
I did some of our old DS/adventure rides on my DR w/ motard wheels.Marylander wrote: Fri Nov 20, 2020 7:56 pm Huh, maybe I could bring out the 690. I finally mounted the front Heidenau K73 supermoto tire I've had sitting around for a year so I should have some ok traction (already had the rear mounted up). The fat 17" semi-knobby Heidenaus look pretty cool... I also remembered to look inside the wheel to divine the mystery of how these spoked wheels are tubeless. The nipples don't go through the rim at all so there are no holes to seal up. They must be mounted directly to the outside somehow. Now I've got a new mystery but one I'm not curious about enough to loosen up a spoke...![]()
I took advantage of the AOMC 15% off deal to get a AL skidplate for it and a supermoto front fender.
... and worn out 606s. But yer a tad crazy Phil.Bucho wrote: Fri Nov 20, 2020 8:56 pmI did some of our old DS/adventure rides on my DR w/ motard wheels.Marylander wrote: Fri Nov 20, 2020 7:56 pm Huh, maybe I could bring out the 690. I finally mounted the front Heidenau K73 supermoto tire I've had sitting around for a year so I should have some ok traction (already had the rear mounted up). The fat 17" semi-knobby Heidenaus look pretty cool... I also remembered to look inside the wheel to divine the mystery of how these spoked wheels are tubeless. The nipples don't go through the rim at all so there are no holes to seal up. They must be mounted directly to the outside somehow. Now I've got a new mystery but one I'm not curious about enough to loosen up a spoke...![]()
