Page 3 of 8
Re: Tires Tires Tires
Posted: Sat May 13, 2017 9:56 am
by Todd34
I've been running the Motoz Tractionator I/T. They were on the bike when I bought it. The rear isn't too bad but it's loud on the road. I'm not sure if I like the front yet. I'm definitely going to try that Shinko cheater rear when I head out to Colorado this summer.
Posted: Sat May 13, 2017 10:00 am
by Todd34
Oh and I've ordered a set of Tubliss as well. Low pressure and no pinch flats sounds amazing.
Posted: Sat May 13, 2017 11:32 am
by beejaytee
Talk to wingfixer about no flats with tubliss [emoji12]
Posted: Sat May 13, 2017 11:37 am
by Rut Row
beejaytee wrote: Sat May 13, 2017 11:32 am Talk to wingfixer about no flats with tubliss [emoji12]
there should be a disclaimer here. IIRC, Wingfixer is a certified tire tester. He is a master of getting flats either riding, or whilst changing tires. :hi5:
Posted: Sat May 13, 2017 11:40 am
by J&J
I think the bib inserts would serve him better. I run the Michelin ultra heavy tubes. They are very thick & heavy but I'm pretty sure that's not what slows me down :lol2:
Posted: Sat May 13, 2017 12:01 pm
by Todd34
Ha! Good point.
Posted: Sat May 13, 2017 12:14 pm
by gots_a_sol
Yea you can still get flats with Tubliss, but the bonus is A) the tire doesn't fall off the wheel and B) You can usually patch/plug the tire and air it back up.
Unless he changed that tire since the last Granville's ride, WF had nearly worn that one down to the cords. Most folks change tires before they get that worn down :lol2:
I'm thinking about pulling the a trigger on a set of the Nuetech Mousse's. The sizes I need never seem to both be in stock though.
Posted: Sat May 13, 2017 1:01 pm
by beejaytee
He was able to plug and fill both in 5 minutes which is the biggest benefit of tubliss in my eyes.
Posted: Sat May 13, 2017 1:25 pm
by Todd34
That's one hell of a benefit. I like the idea of running lower pressure as well.
Posted: Sat May 13, 2017 2:01 pm
by beejaytee
I've been able to get away with as low as 6 lbs in the rear and 8 up front with HD tubes. I can't afford $200 for tubliss when I haven't had a flat in years. I know, I know... famous last words.
