Allegheny National Forest Dual Sport Ride - Sept 17- 20
Re: Allegheny National Forest Dual Sport Ride - Sept 17- 20
606's installed, 14 tooth primary gear installed, chain shortened, oil changed, air filter cleaned,new luggage installed, new (to me) FCR carb installed and tuned, GPS re-wired, all wheel bearing checked, swing arm lubed and test ridden. I think the Dizzer is ready!! IZZIT TIME YET?!?!?!?!?!
What gearing are you running? It seems tough to gear for open road plus trail.
14 x 44. It'll still do 75 without completely wringing it out and still have a fairly low first. That gearing has worked for everything but really tight, rocky single track. We're not getting into any of that, right?
And it still won`t be enough to keep up with the mighty DR!!!!Wingfixer wrote:606's installed, 14 tooth primary gear installed, chain shortened, oil changed, air filter cleaned,new luggage installed, new (to me) FCR carb installed and tuned, GPS re-wired, all wheel bearing checked, swing arm lubed and test ridden. I think the Dizzer is ready!! IZZIT TIME YET?!?!?!?!?!
99 WR 250 Goat
07 DR 650 Mule
14 Super Tenere 1200 OX
07 DR 650 Mule
Challenge accepted!Junior wrote:And it still won`t be enough to keep up with the mighty DR!!!!Wingfixer wrote:606's installed, 14 tooth primary gear installed, chain shortened, oil changed, air filter cleaned,new luggage installed, new (to me) FCR carb installed and tuned, GPS re-wired, all wheel bearing checked, swing arm lubed and test ridden. I think the Dizzer is ready!! IZZIT TIME YET?!?!?!?!?!
Can't touch the KLR though.
I'm going to attempt to not wash the front with a 250mm disc!
Gene-TW200
I'm gonna need to be taken off the list , I got a change in plans , you guys have a great trip and be safe .
Tw-200
Honda Ft-500
ST-1300
DR-650
Honda Ft-500
ST-1300
DR-650
phoo wrote:What gearing are you running? It seems tough to gear for open road plus trail.
Im running a 14 front and I think a DR650 stock size rear (or maybe 1-2 teeth extra?).
Seemed to be a good compramise for offroad while still being pretty highway capable.
I did that tough rocky A option at Michaux with said gearing, and 70+ on route 15 in the same day.
And that is the definition of a true dual-sport bike!!Bucho wrote:phoo wrote:What gearing are you running? It seems tough to gear for open road plus trail.
I run a 14-48 on the Honda and really like it for what ever that's worth....
I am working on finalizing the route and itinerary; hope to have something to share next week.
T-13!
