Rekluse with carbon cover for approx .25 more oil capacity over stock.
Voyager Pro GPS wired to bike power
Scotts Steering Damper
Seat Concepts comfort seat
New set of D606's with only the Michaux Dual Sport (last Aug) on them
Aftermarket fuel pump (better) and metal fuel filter instead of those stupid plastic Mahle filters that eventually fail!
Cleanable fuel filter inline from tank to intake manifold
Also added a Motominded dash with a USB charge port which doubles as a voltage gauge when not in use so you can easily see your voltage/charge status
Bullet Proof Rad guards
Dobek Tuner box added and set up perfectly! Bike runs clean and pulls strong from idle to top!
Acerbis 3 gal tank. You can go over 130 miles to a tank.
Anti Gravity battery with BMS. can only drain so low then the BMS will "turn off" the battery so you don't drain it too far down leaving you stranded.
Bike needs nothing. Runs like a top and clean MD title in hand.
7500.00
I WILL ONLY RESPOND TO PM's, so please don't reply to this thread with questions, if you have a question, PM me please.
