I just swapped both tires on my dualsport bike. Maybebc I semi recently swapped tires on a different bike. I changed both tires pretty easily (for me).juddspaintballs wrote: Wed Mar 25, 2026 6:45 pm I've found it to be all about the technique. Using plenty of lube always helps, too. I also try to change my tires like I would on a trail, so I use either the tools in my kit or identical ones from my toolbox. I cheat on the lube in my pack and bring a small can of WD-40, but at home I'll use actual tire lube.
The good hand tools help
