Let me start with this
cause I'm an idiot. Dropped the dr off the other week at a friends house (whom said he had some time to kill if I wanted to give him the job).
Issues with the bike... it's a kickstart
(can't be fixed). Other issues... oil leak - now fixed. If the guy I bought it from had done what he said he was doing then it would've been fixed pre-leak. The gaskets were over tightened and dry rot = leak. Quick and painless $3 fix.
Now...the electrical issues... Lights wouldn't turn on unless bike was running. Apparently it took two of us to go over the bike with a fine tooth comb for one of us to finally figure out that the fuse was burnt out.
Figures...hours lost when that was the issue. Next issue..brake light flashes when turn signals are on, and brake light didn't work with front or rear brake depressed..... the flashing was caused by my questionable upgrade to led lights bought off fleabay. Why, we haven't figured out..but regular bulb lights work fine. Apparently the upgrade (which I thought would give me more juice for elsewhere..was also sucking more juice then regular bulb lights.
Had rectifiers in place too. Oh well.
The wiring harness and several other connections were also loose. The brake light itself wouldn't work because the front brake switch apparently went up. Replacement coming in about a week for that, along with a new air filter and spark plugs. This thing will be like new when my friend gets done.
Next year...maybe I can talk the wife into allowing me to get some sm wheels sets for it
