Nitrogen charge location
heydek
Post by heydek »
Just rebuilt my DR650 shock and I can't find a shop that can charge the bladder. The only lead I have so far is in Frederick, but I would like to avoid driving 2 hours for a 1min job. Anyone knows of a place closer to DC?
Re: Nitrogen charge location
You don’t have to have nitrogen. You can use compressed air especially on a dual sport. Nitrogen would be optimal in Mx and other racing situations but good old atmospheric air would suffice for every day trail use. Maybe just pump it up and go ride till you end up near a shop that has nitrogen.
2026 Kove 800 Rally
Post by gots_a_sol »
Is it a shrader valve on that shock? I have the set up to do it if you are near me (Bunker Hill, WV)
jgreene
Post by jgreene »
If you can get to Montrose Road at I-270 between 7:00am and 4:00pm sometime, I can bring my kit to work and charge your shock.
Member R&T Club, and GMER
heydek
Post by heydek »
beejaytee wrote: Tue Jul 16, 2024 7:30 pm You don’t have to have nitrogen. You can use compressed air especially on a dual sport. Nitrogen would be optimal in Mx and other racing situations but good old atmospheric air would suffice for every day trail use. Maybe just pump it up and go ride till you end up near a shop that has nitrogen.
I'm going back an forth on this. Problem is I'm taking this bike with me to central Africa in 2 weeks and not sure where the nearest shop with nitrogen is there :think: . I'd rather not have to worry about it before I leave and know my shock will be good for a while.
heydek
Post by heydek »
gots_a_sol wrote: Tue Jul 16, 2024 7:40 pm Is it a shrader valve on that shock? I have the set up to do it if you are near me (Bunker Hill, WV)
It's a shrader valve. Thanks for the offer, I'll keep it in mind, but hope to find something closer to DC.
heydek
Post by heydek »
jgreene wrote: Wed Jul 17, 2024 7:00 am If you can get to Montrose Road at I-270 between 7:00am and 4:00pm sometime, I can bring my kit to work and charge your shock.
That actually would totally work for me. I'll send you a pm, hope we can make it work. Thanks for the offer!
Some motorcycle shops//dealers do nitrogen fills on tires. For example, Bob's BMW in Jessup, MD has the ability. Not sure how they'd respond to putting a charge on your shocks for you.
Air is 78% nitrogen anyway so I've always been a bit skeptical about the value of a 100% nitrogen fill.
heydek
Post by heydek »
@jgreene Thanks again for helping me out. You made that look easy with your pro setup, very impressive :thumbup:
heydek
Post by heydek »
Twist wrote: Fri Jul 19, 2024 6:15 am Some motorcycle shops//dealers do nitrogen fills on tires. For example, Bob's BMW in Jessup, MD has the ability. Not sure how they'd respond to putting a charge on your shocks for you.
I heard it's more about the high moisture in normal air that can cause problems/fluctuations. Either way I won't be able to recharge or rebuild the shock for another couple years, so prefer to play it safe.
